1 - 16 of 16 Posts
So we are painting vinyl windows (i know i know, its not advised) black, with a vinyl safe mix that sherwin williams put together. It was with a mix of blue and another color. The problem is that the blue really shows, even after 3 coats. Does anyone have any suggestions? Also is there anything you can put over the vinyl once painted to help seal it?
510770
I own stock in FotoMat!
Wait... what? After 3 coats there's still tiny spots that aren't covered?
I think he means the paint mix is separating somehow.
OP, what specific paint at SW did you use? Now that there's a coat on it, I'd probably switch brands, and go with a premium grade. Btw, I don't think the vinyl will like the extra heat from dark paint.
It looks to me like the blue is the vinyl, not the paint.
Painting vinyl windows is a crapshoot.
Sometimes it works, sometimes it doesn't. And it rarely lasts very long.
I've had factory painted windows that chip and peel before I even get them off the delivery truck.
And yep, the dark color won't help any.
Also, did you use a roller? That doesn't look like you sprayed them. That's the only way I would even try to paint vinyl frames, but I wouldn't. Not for a customer.
The vinyl safe colors suck. They remove the black colorant and add blue instead, I am never happy with them, you will not eliminate the blue hue.
There is nothing you can put over them that will help in any way with sealing, paint is a sealer.
Advice - I would strip them and leave them alone. I will not paint vinyl windows.
Those looks like roller marks to me. Since paint doesn't like to stick to vinyl, I would prime the vinyl first. You might have to strip the paint, prime, then spray.
Since you are doing this on a vertical surface, 2-3 light coats should work.
1 - 16 of 16 Posts
