1 - 16 of 16 Posts
I got a call the other day about putting a bluestone veneer on the front of a concrete porch and went to check it out.
The porch was formed and poured right into the foundation and then they put a concrete deck on it, but didn't overhang the concrete, they went flush with the wall.
I think originally they weren't planning on a veneer since there is no ledge either. Because it is only 20" though I have a friend at a welding that can make me up an iron ledge.
Anyway, I am looking for ideas on how finish the top of it off properly. I think without the concrete overhanging no matter what I do at the top is going to look incomplete.
I am also a little concerned about water at that joint between the stone and the concrete, even though there is a roof over the porch any water that gets on it is going to pitch right at the veneer and run down the face of it.
I attached a high quality paint drawing of what I am trying to describe.
Any ideas?
Either bluestone the whole top or cut a notch 2 1/2" for a tread to be inset into the concrete. Other then that I got nothing.
The notch idea sound's promising, I will mention it when I meet with him again.
I wish they would have called a mason before going crazy with the porch deck, they could have figured out they needed a ledge with a glance at the plans.
I'm thinking the same as JBM. Best option is the cover the deck with stone, the notch is probably the realistic option, but there is still a possibility of water penetrating. I wouldn't set that stone in mortar, i would set it in PL and make a continuous line of it end to end to stop any water from getting to the wall stone
The stone is ordered and he liked the idea of the notch. Not sure if I should thank JBM or not though.
Now I have to cut the damn thing.
Should give it a nice finished look when it's done though.
lol I know what you mean, but it will make for some good and after photos.
I have to remember to take them, I suck so bad at after photos because usually the last day I am just anxious to tear down any staging, pack up the trailer and get the hell to the bank to deposit my check.
Then I get home and my wife says "How did it turn out?" and I say to myself. "Dammit, I forgot to take pictures again"
I'm way worse with before pics. I'm so busy getting started and getting things worked out and to a place where I can start making money that I totally forget about pics. You can go back weeks later and get after pics
Discussion Starter · #9 ·
I have a thread on here from a few weeks ago about a chimney that I didn't even follow up on because the only picture I have is from way out by the road.
I put the final two courses on and bumped down 6 sets of roof jacks and 5 sections of scaffolding before I remembered I had to take an after picture.
I was kicking myself, and the roof was in such bad shape I couldn't get a ladder up there.
I have a whole folder full of before pictures like that on my computer and crappy far away after shots because I couldn't be back up to where I was.
Discussion Starter · #11 ·
Well I finally got started and got the notches cut, hopefully I can get the steps and the caps put in tomorrow.
I need to pick your guys brains once more though about the veneer.
Originally it was going to be standard 4" veneer so my plan was to build it with a cavity behind and weeps at the bottom, they changed it for whatever reason to 2" though and I am not sure if I should still leave the cavity behind and the weeps or if I should grout in behind them as I go up. I am afraid I will have stability issues while stacking them since they are so thin.
Are aren't quite thin enough to be thinstone veneer though, so I really don't know which method would be best. It is only an 18" tall run thankfully, so I am not concerned about the additional weight on the ledge, just about the stacking and the normal water migration, it is over poured concrete walls too.
Once I get this project finished up I am going to keep pushing for patios and walkways, way easier on my brain.
2 3/4" is the thinnest that you can consider as "normal" veneer. I would grout the back nad forget about weeps. Treat it as a hybrid.
Personally I would also only do 1/2 at a time. 18" isn't much but at only 2" it could get pretty wobbly by the time you're up to height. Would suck to see a big bulge (commence jokes) in the wall the next day
Discussion Starter · #14 ·
I like that plan too. I planned on going overboard with ties also.
After I get the steps and caps on it's shelter time, I hate working in those things.
Stupid cold, it's going to take me twice as long to finish this project I bet.
1 - 16 of 16 Posts
