1 - 20 of 27 Posts
I hang a lot of board mainly com. Standups and ceilings on Chicago, soffits galore you get the picture. I got a job laminating a kitchen and building a small wall for a closet. The existing wall has a Venetian crown that the HO will not pay to match but wants to keep it. I don't finish a whole lot do I just flat tape to it?
Not sure what else you could do.
Put some backing in that upper corner...:thumbsup:
I already did, it's hung ready for tape, but other than a radius tear away I'm not sure what I can do I really don't want to tape the corner to the cove itself, that would involve cutting a million little prices of tape lol
THe IRon Piñata
The time I spent reading this I could have fixed it by now.
Moot point. Cut it tight and caulk it.
You will learn young Grasshopper. :thumbsup:
:thumbup: u got take piece drywall run flat on wall at angle to cove;mark drywall; get multitool; fein saw an cut cove off at your line. Now u have a enough room to slip sheet rock behind for tight fit...like it never happened :whistling
Discussion Starter · #14 ·
:thumbup: u got take piece drywall run flat on wall at angle to cove;mark backside of drywall; get multitool; fein saw an cut cove off at your line. Now u have a enough room to slip sheet rock behind for tight fit...like it never happened :whistling
Not a day in hell would I take a feign tool to Venetian plaster once that lathe starts moving it's all over
THe IRon Piñata
Think they make a blade that wound dig into it just tape it so u stay on good side...an go slow. Plaster gets repaired using a mold..that's poured an cut to shape...u wouldn't have to go too deep in to it anyhow 1/2" they cut it with a miter saw why wouldn't a high speed diamond blade work just go slow....
It gonna be hard...but if I was there...
Getting the tape an cut of sheet rock perfect in that tiny spot...then mud then sanding an still might show. Want moulding to kill into sheet rock not sheet rock into moulding detail is the problem keeping clean in that corner. If scared don't tape just mud maybe a crack maybe not?
I Do it with custom wood crown that u can't find anywhere that will need a knife cut so I could get a new piece. I've had to run boards behind it.sometimes crown is 6" mess that up an there goes the profit...
I would might first install a backer piece that's flush with the studs and tight to the crown. That way, if my radius cut isn't that tight, there's something behind to back the mud. Also will minimize cracking because you can't tape to the crown.
THe IRon Piñata
Why would the client have to pay for you to do that when you took job...
Don't flake out on a client that's how ......you get new ones by asking to be paid an fixing anyways good karma... Maybe he got a friend needs some work....:whistling
Discussion Starter · #19 ·
It was an add on to the contract, and the budget is small. The HO specifically asked me not to touch it. While I agree it would look nice it is substantially less money for me to not form 12' of plaster. But in the same breath I want them to have a nice finish on the new wall
The biggest potential problem I see with the picture is to not use too long a screw on the pocket door framing. Just flat tape the damn cove and move on. If the HO is that interested in looks they'll pay to have the cove detail continued. If not, not a big deal its drywall.
Only a hack would cut into the plaster cove.
1 - 20 of 27 Posts
