I like to stay updated on average pricing for different things. Wether its bending coil or installing counter tops.it's hard to keep up when you do everything.
How did you misspell construction in your username?I like to stay updated on average pricing for different things. Wether its bending coil or installing counter tops.it's hard to keep up when you do everything.
i leave the o out because i use this username alot.and constructionman is usually takenThat's called the "Hot Sheet" - it gets passed around here on CT only once you've passed initiation.
Ive been doing this for 20 yrs. so stick itoh sh&^, not another one.
i leave the o out because 99% of the time constructionman is taken. And by the way i have been doing this for twenty yrs.And i could probably say i do better work than youHow did you misspell construction in your username?
Your not a real contractor are you? come on fess up you will feel better if you do. Its like a good cry just let it out
Wowi leave the o out because 99% of the time constructionman is taken. And by the way i have been doing this for twenty yrs.And i could probably say i do better work than you
kI like to stay updated on average pricing for different things. Wether its bending coil or installing counter tops.it's hard to keep up when you do everything.
post some pictures.i leave the o out because 99% of the time constructionman is taken. And by the way i have been doing this for twenty yrs.And i could probably say i do better work than you
