Hummm
:blink:
Guess no one has done this.
When I get it done I will post how it works
Thanks
:blink:
Thanks
I use a tankless gas water heater to heat my spa. Works fine.
You want to do something completely different, may not work. Making this a zone on an existing heating system will result in mixing of the spa and heating water. I don't know if that will screw with your system or not. If that works for you, the next issue is pressure. If the heating system is a pressurized system, I don't think you can make this work because the spa is obviously non-pressurized.
The spa pump will pump far more than you can put through the boiler. That means you can only pump some of the water through the boiler then mix that back into the return water stream. Getting this set right is a challenge. You must provide adequate flow and pressure to fire the boiler without over-restricting the flow from the spa pump. In your case, you will be dealing with both the spa pump and the circulating pump so it will be even more difficult.
As for the control for the zone valve, that is pretty easy. You can get a bulb type sensor on a thermostat. The sensor inserts into the pipe through a threaded fitting, generally in a "T". That would open the zone valve and turn on the circulation pump for the heating system.
Now this I gotta see!Hi everyone!
Iv just added duct work to use the same wood stove running my hot tub and circulation through my heating system to an old electric cloths dryer I pick it up at the dump yesterday.
I now dry our cloths and heat the water to the hot tub along with heat our home with wood.
Fun.
Ill update the whole system if anyone want to know more.
Maybe I can post pics of the system.
I changed to wood stove last week replacing it with a (Nashua) brand, a friend sold me.
It has a wonderful advantage over my last wood stove in that it has a blower assembly. This is perfect for hooking up a dryer to it.
no more gas bills!!!!:clap:
It is also a time machine.Is it also a time machine?
You got that right I got a $1.2 M job and I can't get to it cause I'm so busy doing these little projects.Wow...I can imagine this being done, but you've got to have lots of spare time on your hands for it! The time it would take to cut enough wood for all this is mind boggling...and around here at least cut firewood prices have gone up too high to make it cheaper than gas!
Yes separate loop is what I used. I cut in a separate hole in the boiler and taped threads along with high temp gasket, so its completely separated from the hot water baseboard heat loop that also is wood/oil fired.Hey in regards to a wood fired tub. Couldn't a fella circulate the heated water on a separate loop? I think the tump pump could circulate water across the hot water coil as well.
