1 - 20 of 30 Posts
Contractor of the Month
I'm looking for a quality hole saw to cut in five inch can lights.would like one that is diamond impregnated for cutting through lath and plaster would like a diameter of 5 1/2" - 5 5/8". Any recommendations?
I think mine is a greenlee.
Head Grunt
Lennox or blue mole all the way IMO. Quite often in an older home like this i pass the buck onto the customer for the saw. If i am chancing on ruining a saw then someone has to pay. The only other hole saws i would consider is Milwaukee with the carbide tipped teeth. But i do not think they would work well for finesse cutting for like a recessed light where the trim ring may not cover any damage.
Plaster will ruin one in only a few holes...but the abrasive ones are kinda slow.
Head Grunt
Exactly why i do as Chewy stated and run them in reverse. But even then damage can occur and someone has to pay. I as well as you and others here are not out to do hack work so if the customer wants a good clean job than they pay, part of that charge is for tool wear/tear.
Reverse still screws them pretty hard, you can get 3-7/8 hole saws for around 12 bucks and throw them out as they wear down...but the big ones arnt cheap. The last big job I had in a wood lath and plaster house I started with an abrasive saw then switched to a regular one to finish the cut. The speakers I used a multimaster grout blade to penetrate the finish coat and half of the brown coat, then used a bi-metal to finish the cut.
I own stock in FotoMat!
You may as well buy a new one for each job. Plaster is a pain.
Be careful it doesn't bind up and send you flying off the ladder!
I've had a Greenlee carbide grit 6-3/8 for 20 years. Sheetrock, plaster, vinyl, steel, hardiplank, plywood..... Still using it.
1 - 20 of 30 Posts
