1 - 7 of 7 Posts
I'm framing a hip roof with trusses for the fisrt time in 20 years, last ones on track houses in phoenix az. Do you still drop in a 2x6 dummy hip, that really carris no load? That's how we used to do it, is that standard hip truss framing on east coast as well?
That will all depend on the manufacturer. I would hazard a guess and say it will not be quite the same as a west coast style. Your hip may be a girder instead. Setback is most times 9'.
What about asking for the truss specs? That would tell you right away.
That's apparently a closely guarded secret, I like being able to look at my plans at least a couple days before I start a house, but this times its trial by fire, its all good, once I know the pitch I'll just cut the hip jack rafters according to the run, and nail something somewhere, itl work, I stick frame hip n vallys like a beast, but have only been setting gable roofs with trusses lately, I got this, I'll ask for a quick glance at the truss plan, thanks man, have a good one
Not sure why your truss plan is such a secret. I often can get a preliminary plan prior to any framing in order to bid. Once you see the truss plan, it will be a no brainer. Everything will be trussed, probably with dropped top chords to allow you to lay over with flat 2x4's.
All the hip trusses I've done (not many), they sent out a special truss made from 2x4's on the flat to lay over the trusses.
I've only done 4-5 hip trussed roofs out here in CO. I just follow the truss design/spec sheet.... mine are perfectly detailed, and never had any problem....
What I'm confused about is what you guys above are talking about.
All my truss designs have had a "hip truss" (with jack trusses running off it). The hip truss simpsons right onto a girder truss.
I've done normal and inverted hips.... both very similar in design.
Maybe it's my snow loads in this area and there are different less expensive designs.... but I can't figure out what this "2x4 flat" stuff is.
Thanks for any info/explanation
Best
Thnx you guys, I figured this sits was just gonna bull**** homeowner crap, I built the hip ends on the ground, with subfascia, set them with machine, no crane, ripped a 2x4 on a 45, it lays flattish as a hip rafter, then hip trusses r 1.5 inches lower allowing for 2x4 on the flat nailers as hip jack rafters if you will. That was this setup, not the same everywhere. Now I 1.5 days to sheath the roof with a 4 man crew, including myself, and 2 of those guys r afraid of heights, love it,
1 - 7 of 7 Posts
