1 - 6 of 6 Posts
Grab bar install. No backing. Can open the backside of one wall but not the other.
Question is how many of you have used both and which one would you prefer?
I've used many zip toggles and they are very strong but never used wingits.
I've used WingIts when there is
no good alternative.
When you put the blocking in the
first wall you should be able to get
a feel for the drywall installation.
http://www.wingits.com/documents/CONFIDENTIA1.pdf
You can read the UL tests, I did my own
standing on one and bouncing my
180 lbs on it.
The Deck Guy
The Hilti zip anchors are rated for some serious loads if I recall. I think their strongest rating is with 5/8" rock, but the 1/2" is not shabby.
Is the substrate behind the tile drywall or cement board? That might make a big difference in rating with any anchor.
I'm going to order a variety of wingits to keep on hand and will let you know how it works out later this week. I like the fact that they are stainless.
Thanks for the replies!
Did that job yesterday. Installed 2 -18'' grab bars, Wingits performed as well as they stated. Also used the Zircon model 520 studfinder to scan through ceramic tile and it worked great! As with Wingit system you stay away from them.
Greg, it was drywall,and if it was cement board those thing would never come out.
Neo, thanks for the heads up on those wingits:thumbup:
Did explain to HO they are only as strong as the wall and 2x backing is the way to go.
1 - 6 of 6 Posts
