B
bnjjunk
·Guest
I recently hired a licensed contractor to move my two air conditioning condensers to a different location. One is a 3 ton for my upstairs and the other is a 4 ton for the downstairs. When they moved them, they hooked them up incorrectly and hooked the 3 ton condenser to my 4 ton unit and the 4 ton condenser to the 3 ton unit. I found the problem when I turned on the downstairs air and noticed that the air was warm. I wen toutside and found the 3 ton condeser frozen and the fan was not operating. My question is this:
I am sure they will come and switch them back (they actually hvae some more work to do modifying the ductwork as well), but is there damage to either condenser or unit I should be concerned about? I heard you cannot mix different size units with condensers. I don't wanna get ripped off. What should I do and what is the best way to protect myself? ANy advise wold be very much appreciated.
