Hello all,
I have been working on a 150sq+ roof since before the holidays (due to bad weather days and such) I was brought on by a fellow "contractor" who gets all his work from his uncle. I have several items I would like to point out and ask opinions on:
It has always been in my best practice when stepping shingles to go *at least* 7" away from the shingle below.... His steps were 1 1/2 and he said "this is fine" Now, wouldn't this allow water to follow the short-stepped pattern right into a vulnerable point in the roof?
When doing the valleys, I prefer to weave and then do a "no cut valley" If anyone is unfamiliar with this practice, once the one side is weaved up on to the opposing roof, shingles are laid with the reveal facing downward diagonally following the valley, therefore making it unneccessary to chalk a line and cut. Now it has always been my understanding that you run the higher pitch roof on to the lower pitch, to avoid pooling of water and the possibility of water running back into your weaving. This guy said "I looked it up online and you are wrong! You F&#[email protected] up the whole job and I don't want you on it anymore" My questions would be:
I am not proud to say I put my name on this job, and after all the unnecessary berating I had to take, I am starting to even doubt myself. Help out a fellow contractor?:sad:
- If this was an experienced contractor, wouldn't he be sure of himself enough to not have to check online?
- Was he justified in ending our contract early?
- Should I be docked pay, which is what he is threatening
