I willl go first
Tree fiddy
Tree fiddy
your installation method may not be the best; maybe a better idea to install 2x4PT sleepers for nailing the flooring onto.
Fixed....If you have a concrete floor you will have to use a vapor barrier.
Thanks casemill, after extensive research 3/4 ply is the way im going. I have not tested the moisture content yet but the concrete is over 50 years old on grade so it should be good. I would like to put a vapor barrier down any way for some extra insurance, i was told to use cutback adhesive for the felt paper, but cut back adhesive is hard to find, what do you have for a suggestion on a adhesive to lay the paper that is a decent moisture barrier in itself as well?
Here is an article from FCI about this subject.Thanks casemill, after extensive research 3/4 ply is the way im going. I have not tested the moisture content yet but the concrete is over 50 years old on grade so it should be good. I would like to put a vapor barrier down any way for some extra insurance, i was told to use cutback adhesive for the felt paper, but cut back adhesive is hard to find, what do you have for a suggestion on a adhesive to lay the paper that is a decent moisture barrier in itself as well?
...So next time call a professional to install your floor Holmes!
