1 - 20 of 25 Posts
Hey all,
Just looking for some advice here,I am installing oak 3 1/4 hardwood flooring.What is better to use for nailing it? Staples or nail ?? :thumbsup:
I've seen flooring contractors use both. My hardwood guy prefers staples, as do I. As far as I know, one difference is that if you are using nails, you need more of them.
You can go to the manufactures web site and check their install manual.
KemoSabe
Hey all,
:whistling
Focusing on solutions.
I've demoed floors nailed with both. Stapled floors don't hardly leave a staple in the floor & there's hardly a damaged plank. Not the case with cleats.
Let me ask you this for comparison. Which will hold better, a ring shank nail, or a 16 sinker?
Hey, good point. Now that I think about it, every floor I've pulled up with staples, the staples do come up with the hardwood.
Thanks for being on the ball. :thumbsup:
KemoSabe
I hear ya..lol...
I mean installing it...............
I've heard staples , because it is less likely to split..
Thanks
I haven't done many floors, but the ones I have, either engineered or solid, got stapled down.:thumbsup:
MHIC licensed contractor
With 3 1/4" plank flooring you can still bang a plank straight with cleats. I'm not sure it that can be done with staples. Cleats cost more , but i have more faith in them.
Remodeling Specialist
I mostly use staples unless specified not to by flooring company as in the case of Bamboo I just did. I have never been able to pull staples out easily and less splitting. Most cleat jobs I'm not impressed with the holding power on plywood. In fact I just did one that the bamboo required 2" cleats and I had to tear up a board that was fully nailed and it came out way too easy.
I'm a bit nervous what this is going to sound like in a few years.
Im going to be installing a prefinished 5/16" engineered 5" plank later this week and ill be using staples. I feel more comfortable with the holding power of a staple but everyone has their own opinion. For you staple guys, what size are you using? Any of you guys using regular 18g guns as appososed to the flooring guns?
Contractor
I think the staples in my gun (fires cleats too) are 15gauge staples (?)
consider glueing down your engineered floor. A full spread installation keeps the floor tight for many years-especially in old houses w/ uneven floors (joist buckeling). Isn't there a recommendation for using adhesive/glue on planks larger than 3.25?
Contractor
I didn't spring for the MIIIFN but picked up a harbor freight flooring nailer/stapler. Used it to install about 1500sqft of flooring haven't had much to complain about....if I were to install a lot of flooring I would have bought the Bostich.
1 - 20 of 25 Posts
