Recently delivered 2 cartons of 5" pre-finished red oak "cabin grade" hardwood to a job site to allow acclimation. Only 2 cartons because we were planning on replacing some boards that had been damaged as a result of cupping. All indications were that the original floor was not properly acclimated prior to installation. I'm aware of what normally causes cupping and although we disputed the proper acclimation finding, we couldn't prove otherwise. The house is infrequently occupied, air heat and cooling, timber frame with insulated panel exterior. Super tight home, HRV set to run intermittently and vent the baths.
The bands were removed from the carton and the boxes cut open. 2 weeks later I returned to take moisture readings and discovered every board cupped, throughout the box. Moisture read 8-10%, as did all the other wood in the house. Returning the wood to a super dry environment has all but eliminated the cup, still is slight. Less than 6% moisture content, lowest reading on my meter.
RH in the house is elevated, but not extreme, 50-60%.
Original floor remains cupped, but acceptable to the Owner, thankfully with the exception of a few boards.
Basically, unless I dry the house to what I would consider an unhealthy level, I am unable to acclimate this wood.
Anyone have any thoughts on this? I'm beginning to question the reasoning for the initial cupping.
Could the wood be too dry before the finish was applied?
Thanks in advance.
Thanks in advance.
