OK, I have moaned and groaned about this problem for 1/2 a decade. When I first bought the machine I didn't have this problem. After I got the knives sharpened for the first time I did. And ever since that I have had a problem with chips coming around with the cutter-head and leaving marks in my wood and also chips getting crushed into my wood by the rollers.
The first recent thing I did was flip over the orange plastic chip guide. Put the bevel down. This allows the chip guide to be pushed forward a little more than before. This eliminated about 10% of my problem.
I was moaning about the problem again. I had some free time to blow while waiting for someone to show up. I was told time and time again it was my vacuum system, I knew better. So I was feeling around with my hand while the vacuum was on (machine off) and noticing how much vacuum was around the cutter-head. I also noticed while I was planing that the problematic chips would come from in front of the last outfeed roller, in between the roller and the casting. Well I felt for vacuum in that area and there was essentially none. I wondered why. So I pulled the guards off and there is no way for any vacuum to get to that area. So I made it so it could. I drilled a series of nine 9/16" holes in the casting, spaced apart 1 1/4". Now I didn't have a lot of vacuum there, but there was some. It seems to be enough to keep the chips from falling down to the board.
I have only run a test board through it. On fast speed taking 1/8" off a 8" wide poplar board I got no chip fall. I still had a little bit of chips being beat by the cutter-head, but very little compared to what I usually get.
So, it may not be a perfect fix, and I might make the holes bigger or even connect them and make it slot. But it is a start and it is something that actually is making a big difference. So calling it solved may not be the perfect term for it, but it is the closest I have been in 5 years. Here are a few pics with the top guard off
