Gutters. How long for one run?
97K views 80 replies 34 participants last post by  King_Chewps
There's been an indirect inquiry sent my way but I've not been approached yet about a job for a very long run of gutter.
A person has a building 210 feet long and is inquiring if it's possible for me to install one continuous length of 6 inch seamless. This far exceeds anything I've run off to date.
Can it be done? Should it be done? What would be the best way if possible? I'm thinking it would be impossible to pitch it even with crowning at the midway point and it would have to be installed level with several downspouts.
Although it appears that the job won't take place for quite some time, I'm curious to know everyone's take on this scenario in case it does materialize and come my way.
All input is appreciated.
#47 ·
On the restaurant we're doing now subbed the flat roofing to a company who's been around for over 100 yrs. Insurance company paid for the roofing work both pitched and flat so decided to call in the heavy hitters and have it done right. Anybody ever see 1.75in hail damage a hot mop roof?
The salesman who's been with the company for 38yrs said his son is a roofer/siding/gutter guy. We were talking gutters and he said his kid has made a killing on his gutter machine. His best money maker was the job he did where he ran off 700ft of gutter ONE RUN. I asked how big of an army he used to hang it and he said he just drove his trailer along and hung it as it came out! Must have been pretty low to the ground to pull that off!
#52 ·
I would say do it, but make sure you have enough downspouts installed for easy and quick flow of water. If you have the water sitting in the gutter too long before drainage, you will have deterioration to the gutters. I would also recommend to the property owner to install gutter guards if there is a lot of trees around. If the downspouts clog or a dam is created then rain water will accumulate and weigh down the gutters.
Devin Mahdi
Dallas Roofing Company
#55 ·
long gutter?
You shouldn't have any issues installing that gutter. My company (1 Fine Gutter) is fairly new, and we found out real fast how to install the long one's. It was our third month in business when we were called about installing seamless gutters on a horse stable, when we took the measurement, we were a bit intimidated. 171' on each side. Using .032" aluminum coil is key. Snap every hanger into place as it feeds from machine, and have done buddies ready to grab on. Both sides turned out really nice, but we were sweating the entire time, one mistake and it's over... Take a look on Facebook for 1 Fine Gutter. pics of that job are posted. 1 Fine Gutter, Hang With The Best...
#58 ·
Ever use the pre made expansion joints? I've got a couple in the trailer just in case but have not yet had occasion to use them. They're kinda pricey.
Been in business 5 or 6 years now and 87' is the longest I've run into yet. I priced the local fire hall earlier this summer. They never got back to me and never hired anyone else either. I'd definitely do that one in 2, possibly 3 pieces.
#59 ·
Client wants a seamless continuous span , it is 70 feet long two downspouts on either end , house has foundation problems so it slopes to one side significantly. Should I do one 70 foot continuous span or put in an expansion joint with end cap at 40 feet? I think with the slope to the house the gutter will not drain correctly if not continuous with no obstructions
#60 · (Edited)
Throw up a seamless 6” gutter and it might be able to handle most of the volume. Still have two downspouts though. Try to get at least some of it to run towards the other hole.
I’ve done an entire complex of 70’ runs with one downspout. (6”&3x4 Design wouldn’t allow a second. Told them not responsible if they over flow. Was able to handle it miraculously. Probably overflows during a monsoon type of Rain, but so do rivers and streets. Lol. Was 15 years ago and they’re still up.[emoji106]
#65 ·
This is an old thread! I've done a few miles of gutter since then. Probably the longest one piece run I've done is 86 feet. We've done a lot of one piece runs in the 70'+ range over the years with no issue.
Just did a pair of 125's on a job last week but those were seamed in the center with a 2 inch overlap. Fortunately the building ran in our favor and we didn't have to crown and run both ways anywhere on it for downspout placement. Both sides of the building pitched toward the same end. Of course there was more than one downspout per gutter but that was easy with the entire gutter pitching in one direction.
