Gutters. How long for one run?
97K views 80 replies 34 participants last post by  King_Chewps
There's been an indirect inquiry sent my way but I've not been approached yet about a job for a very long run of gutter.
A person has a building 210 feet long and is inquiring if it's possible for me to install one continuous length of 6 inch seamless. This far exceeds anything I've run off to date.
Can it be done? Should it be done? What would be the best way if possible? I'm thinking it would be impossible to pitch it even with crowning at the midway point and it would have to be installed level with several downspouts.
Although it appears that the job won't take place for quite some time, I'm curious to know everyone's take on this scenario in case it does materialize and come my way.
All input is appreciated.
#2 ·
It CAN be done, but it should not be done. Anything over 80 WILL oilcan and buckle. we did a job last winter 86', I pushed it knowing what I was doing was wrong but figured "eh 6' won't matter" wrong we oil canned in two spots. Just a friendly remidner from God to stay on the right course and not be like every other joe hack out there. Now we have to cut the gutter at the oil can and install expansion joints. Problem is I should have done that in the first palce and I knew it, but now I get to pay for it.... grrrrrr!
You're going to have to hame multiple pitch points/crowns I don't like to put more than 40' to one downspout. I can stretch that to 60' if it's oversized. So you'll have a series of highs and lows in the 210' length of gutter.
#20 · (Edited)
Ok, I have to ask Grumpy. What exactly is "oil canning"? A buckle or folding up of the gutter in one spot?
As far as my original question about the 210 footer, that never came to pass. However I did an estimate yesterday with one run of 82 feet. I explained to the customer and the home builder that it should probably contain an expansion joint at the halfway point. They didn't seem thrilled by the idea. Bad enough that they're adamant about having a single 3x4 downspout on a run that long because there's a drainage area at that end of the home in this housing development.
For what it's worth I install 6 inch gutter at .032 thickness.
#5 · (Edited)
Longest run to date has been 68' 4". Crowned at the center and spouted on each end. Not familiar with expansion joints, Grumpy. Never had to install one and my local supplier doesn't show anything like that in the seamless gutter section of their catalog.
I've seen it recommended to end cap where you want the joint and begin the next section with another end cap. From there you can fabricate your own flashing to cover the butted end caps. How is it done in the Windy City?
FYI I've got a 6 inch machine and use .032 coil. A 350 lb. roll will do about 600 feet.
#7 ·
The way I've done expansion joints ( I think I got this detail out of the SMACNA manual ) is to slide one piece of gutter inside the other about 2-3". Install an end cap (hand made) on the inside of the inside section of gutter right at the end. Install a similar end cap about an inch away from the end of the inside piece of gutter to close off the outside section. Fabricate a loose fitting cap to cover the gap.
#8 ·
Online research is showing that Alcoa makes a part OG25 expansion joint and that Mastic (still Alcoa) has a 6 inch gutter expansion joint.
However they don't seem to be the easiest part to track down.
As seeyou says, I've also found a PDF document that shows notching the lip back 2 inches and sliding one end into the other and sealing. This document also recommends riveting this area, so I wonder how it would be able to expand/contract?
#9 ·
Doesn't sound like it would. I've certainly never seen anything like that in the field. The expansion joint I described is less visually obtrusive than the "store bought" ones. Just looks like a joint from the ground.
#14 ·
Just picked up a couple of jobs with semi long runs. One is a straight shot 70 footer and the other has separate straight 60 foot runs on a garage and a 54 run on a porch. I'd be crowning these and downspouting each end.
Anyone have a recommendation on expansion joint spacing? Thanks!
#17 · (Edited)
Thanks for the advice, guys. As I didn't get a chance to check for any responses before I went ahead and installed the run, I played it safe did an expansion joint at the halfway point of the 70 footer.
It did happen to rain this afternoon while I was working on the remainder of the job and things are looking like they're flowing in the right directions.
I don't think I'll lose any sleep over throwing an expansion joint into a 70' run.
I forgot to mention that this is one of those 4 sided, pyramid shaped roofs, so there are 4 outside corner miters, no end caps where the longest runs are. Seem to have gotten several jobs on this style roof this season.
But where the joint is I went with the method suggested by seeyou. Doesn't look too bad at all. In the future I can see using either that method or the end cap method with probably equal success.
#21 ·
Hey guys. I tried forever to hunt these things down as I needed 2 for a job with a 50 ft run on each side.
There are a couple websites that offer these Alcoa 5" neoprene expansion joints but they want a premium.
Locally, they are $40 each and online they are selling for $30 each shipped.
I found a 12 pack and have 10 remaining if anyone is interested. They work with 5" K style aluminum gutters.
Will sell $12 each with free shipping. Send me a private message if you are interested.
#22 ·
Wow, that was an old thread! I've since put up thousands of feet of gutters. Amazing how foolish you feel about questions you asked way back when! :whistling
I don't claim to be a wizard by any means. But I definitely know a lot more, have more equipment and get things done a heck of a lot faster than when I started out.
#26 ·
How tall are you? I'm asking as I'm 6-5 and holding a 70' piece of 5" .032" over my head both ends are close to touching the ground.
Roughly 35 feet between me and the end and say your partner is up the gutter another 35 we are now 140 feet. You still have 85 feet to deal with.
I know I'm awesome, I'm sure you are as well but man I gotta ask how you did it?
#28 ·
I agree with you that using normal techniques would be utterly impossible when attempting a feat of this nature. But rest assured it was just the two of us and a little ingenuity.
Did I also mention that this piece had to go 25 ft up?
AB is Alberta.
I will eventually tell you how we did it but I want to see if anyone can deduce how we did first.
#31 ·
AB is Alberta.
Ladder brackets. Just kept bumping them up one rung at a time?
#35 ·
Run it off, and lift starting on one end to the other in 20' sections, using twine. Keeping the tailing end down so that the gutter stresses. Just enough to keep it solid. No different than carrying 40' sections by yourself. having gutter hangers/spreaders/stiffeners in place help too.
LOL I saw a 5'2" dude hang a 40' section on a second story eave...Standing on the roof. LOL His helper (son) was afraid of heights LOL
