haha
I worked it out far out they need a standard system to class abrasives
No aftercooler yet, got a boat to do tomorrow (with soda) I'm not sure if the ASB media valve will take the glass, I don't know what steel is inside them ? glass might grind it away, it's pointless asking them, they will only tell me to use soda through the valve, ABS has more secrets then the CIA
Yer, done a couple of boats, I have been using a #4 nozzle @100psi but tomorrow I will try the #5 @ 90psi (due to air requirements) and I will turn up the media up a bit, have to get this one done as quick as possible.
Because ASB only recommend using soda through their gear they only use a mild steel nozzle's not tungsten or any thing like that, but I will still run some glass through it to try it out
