This is probably a little off topic, but I figured you guys would know how.
I have a "WeedEater" Featherlight SST 25HO trimmer.
The thing won't run much faster than idle, even at full throttle. I replaced the fuel pickup/filter, the spark plug, and played with the carb settings, which got it to run a little better, but still won't run at full RPM.
I called the manufacturer, and they told me "Only an authorized service department can adjust it, because you need "A Special Tool" to adjust it".
So I'm like, uuuuuhhhhhh, you need a screwdriver to adjust it, all I need to know is how many turns to adjust each of the two screws.
I think you probably get the picture by now, so my question is; What are the correct carburator settings for a WeedEater?
Thanks
Thanks
