1 - 14 of 14 Posts
I am relacing my countertops with Granite. Problem is I have a center island that is currently butcher block and it has a 29" overhang on one end that we currently use as a breakfast bar. I'd like to have the same dimensions with the Granite but I keep getting conflicting information as to how much support I will need to make sure the Granite doesn't crack. I plan on installing corbels for support. How far out do they need to be to give proper support?
There's a product you can buy also called CounterBalance. I've put these in on a few islands. They're a T-Shape
http://www.chemical-concepts.com/products.php?sid=309&limit=0
I looked at those but I wasn't sure if they could be installed on my island because I don't see what it is anchored to inside the cabinet. It looks like it mounts on an iterior wall but I only have one divider and it doesn't run the right way. What else can you mount it to? Do you use an adhesive to attach it to the Granite?
Talk to your fabricator stone varies in strength.
I have seen 1/2" x 4" steel routed and epoxied into the stone, and have been seeing fiberglass rods kerfed into the stone. You have to be sure the cabinets will stay on the floor and or together if someone sits on the cantilever.
At 29"' you could use table legs and an apron if the look is right for the design and would work better than corbels
Bill
29" & no support, no way. Find a nice way to support it or keep it at a 12" overhang max.
Use a welded frame
Have a welder weld you up a frame using 1/4" angle iron. You can bolt it to the inside of the cabinet and hide the overhanging portion under the granite. A well designed frame could easily support that overhang and you wouldn't be able to see it.
Good luck.
If it's a counter balance it will use the weight of the granite on the cabinet supported side to support the over hang side. You would more than likely use a high strength adhesive to attach it also
I'm on a boat!
One way we've done large overhangs is to build a frame with the same material as the cabinets and have 2 decorative legs on the outer edges. This has more of a built in table look versus a clean overhang without any visible supports. Depends on what style you're going for. Regardless of the method used, it will need support.
1 - 14 of 14 Posts
