sure, a bad board may present these symptoms. there are other culprits that may be responsible for the problem. there may be bad wiring from the t stat to the fan relay control in the furnace causing this to happen. the hi limit my be tripping off due to hi temp in the furnace, as well as the hi limit going bad, which will trigger the blower motor to come on.
