I would be very careful running those heads! I have never seen a head with a Zero degree cutting angle! It will require a huge amount of horsepower, and I would quess that the knives will dull and start burning very quickly.
The "standard" cutting angles have been 12 degrees for hardwoods and 20 degrees for softwoods for many years, with 15 degrees being a compromise and adjustable 12* - 20* heads being common.
Schmidt usually has all their heads in stock, and CT Saw and Tool carries a wide variety of heads in stock in many brands and grinds profile knives for all heads - including W & H machines, which they also stock.
If you are having trouble with your moldings, it is likely not your fault, but that of the cutting angle.
Another problem with "one off" heads is that you will likely have to leave the head with a profile grinder to get new knives ground properly.
I hate to be the bearer of ....... but be VERY careful.
PS!!!!! On second thought, I would call Jim Povinelli, owner of CT Saw and Tool and a third generation grinder, and ask him about it. When cutting with a standard head, both centrifugal force and resistance to the wood, forces the knives INTO the head rather than the reverse. Tell the lady who answers the phone that Jim Chestnut told you to talk to Jim. Tell him that too. He's a busy guy.
Regards,
Jim
