41 - 60 of 70 Posts
Discussion starter · #44 ·
What screws are you using to attach the go board? I'm having a hard time finding backer screws with the larger head or ones that don't have those ridges under the head that tears up the face of the board.
I thought they released goboard fasteners and screws but I have yet to find these anywhere online, what's up with that.
Last time I installed GoBoard, I used some backer screws from one of my suppliers. I think they were "Primo Tools" brand. They didn't have any of the ridges and worked fine.
The GoBoard product range is pretty limited, and I'm guessing most suppliers won't carry their screws when they already have some from other vendors.
For the adhesive / sealant, I actually use one of the Sika alternatives they list. I can find it at Home Depot in the large tubes. It is far more economical and I like how it skims over/ sets up faster than the GoBoard product.
Also, see if you can find 4x8 sheets. I will sometimes do a mix of 4x8 and 3x5 sheets to minimize waste and seams.
I have used regular cement board screws but don't like them...they "cut" the surface too much for my liking. Actually use an 1-1/2” electrogalvanized nail mostly. It leaves a slight dimple to fill with sealant. Holds very very well.
Why not use kerdi fabric over the existing drywall? It’s about $1/ft compared to about $1.5/ft for the go board. Once you add in band and corners it’s probably a wash; you stay with one system and you don’t have to screw around with fasteners and caulk.
Because it sucks to work with and you have to mix thinset to install.
Discussion starter · #56 ·
Drywall/cement board is terrible to work with. It's heavy, dusty and unless you adhere the kerdi exactly right you'll get air bubbles everywhere. I helped a buddy with a job a while back and we had to cut each air bubble then patch with kerdi.
Really? I think it’s super easy, time consuming but easy.
Except for the heavy part, I’ve never had an issue with it.
Kerdi board is my go to.
Tom
Discussion starter · #59 ·
Tom
Mostly just issues with the heaviness and dust. It's to cumbersome for one person and then when I need to cut holes in it dust gets on everything.
41 - 60 of 70 Posts
