1 - 5 of 5 Posts
hi, i new at the glass window and don't know which is good. this is one of the spec that i have for one company not sure it good can you guy give me any idea.
Cardinal Glass System with Low E (squared) glass
Low E(squared) Glass is 2 layers of a silver metallic coating that is applied to the interior pane of glass and blocks approximately 84% of the harmful UV Rays
3/4 Insulated Glass Unit
1/8 Thick Glass
Double Weatherstripping
Brass Rollers
Deep Pocket Sill
Metal Locking System
Fusion Welded Vinyl Corners
45 degree built Weep Hole System with cover
100% Virgin Vinyl - Will never peel, chip, flake, crack or fade
.29 to .34 U-Value and SHGC
20 Year Labor Warranty from Amerimax Building Products in Sacramento
Lifetime Material Warranty
1 - 5 of 5 Posts
