1 - 3 of 3 Posts
A Maryland Handyman
Just wondering if this is something the pros have seen often?
Yes, the LINE feeding the GFCI tested correctly and a new GFCI works and trips correctly.
The bad GFCI had working HOT and Ground, but the neutral was dead on both plugs. A test between HOT and Neutral terminals on the bad GFCI was good. The built in tester even tripped and there was no LOAD attached. Thought this was a strange internal defect.
Lots of issues with older gfi's I repuposed one this weekend that protected the load circuits but the outlet itself is dead acording to my "cube" tester .
The downline outlets test and work and are gfi protected ,the "cube' will trip the dead outlet.
Put in a new one and move on
I own stock in FotoMat!
The test button works because it can send the test current to the neutral upstream of the open contact of the neutral.
Not unusual.. just a defective GFCI. Install a new one and call it a day.
1 - 3 of 3 Posts
