1 - 18 of 18 Posts
I started to lay out an 18" sitting wall that would butt to two 24" piers. I thought I layed it out for 3" reveal on each corner of the pier. Surprise, because the piers are not parallel to the radius I do not end up with my 3" reveal on the inside corner.
This would really look bad especially when the radius bluestone cap goes on.
We're going to change the sitting wall to 16". At that point I can blend the last bit of the wall into the pier.
Glad we caught it early. This is why I'm a nut about layout.
· Have Trowel, Do travel
i dont understand "butt in-to" "3 in reveal"
is it that the footing doesn't run "square" into the pier?
But because of the angle of pier the wall would actually run to the corner with no reveal.
Sorry for the confusion, it is a bit harder to describe than I thought.
I'll make a drawing when I get home.
Perfectly clear to me!
You assumed it would be a square to tangent dimension, & hence the 18" dim, but in fact it's an odd intersection angle.
A 24" clmn minus an 18" curve wall = 6".... div by 2 = 3" reveal each side. The problem is that is a bstd intersection.
Intersecting curves and straight wall can be tricky at times.
Joe
Joe
It's just basic geometry...not quantum mechanics, but I get the rub! :laughing:
Sometimes the simplest way to describe something is to just use the proper terms.
I don't even know where I'm posting, & didn't mean to ruffle anyones feathers.
Carpenters typically have to deal with trig on occasion, probably more so than Masons.;)
BTW,
My dad was a German imigrant, life long mason.:thumbsup:
Joe
Yeah, I'm a big believer in geometry knowledge as well. So long as I have a benchmark i can layout just about anything with string and a tape measure (really don't even need the tape measure) Well I guess I'd need a couple books as well cause no way I can remember all those equations
· General Contractor
I believe that any mason can benifit from a study of geometry...Vitruvius, Da'vinci, Cathedrals, Scared Geometry, that kinda thing. Heck, there are even fraternal orders out there who are named after what we do, who seem to be all about geometry.
What... no iPhone? :thumbsup::laughing:
Huh. I always wondered what that stick with all the lines on it was called.......
:eek:fftopic:I just noticed your profile picture... I was just there and took a snap shot of that building designed by Antonio Gaudi... that is some cool architecture :thumbsup:
1 - 18 of 18 Posts
