For construction, anything less than a 6000 and you will be tripping the breaker
A good load chart will also list the possible surge currents of various tools/appliances. Some stuff needs more juice to start up than it does to run.Just take a load chart of what tools you will be using most, Add up the watts and amps then find your perfect match!
I'm surprise that you are having problems from a 8k generator, that's a nice size. I'm not sure how much a power ladders use. Does the generator have two separate circuits? Or is your hoist a little older?? maybe a big compressor pulling alot of amps? I mean having a generator that size you shouldn't have much problem,anyony used a generator to power a elctric roofing hoist ? I have a 8k generator that suppose to handle a whole house including fridge tv's etc...
The fuse keep poping from using a hoist / comprassor and a skill saw. Maybe its too much for a generator period
Well make sure you are separating the two from another, even thou the compressor demand alot of amperage once the tank is close to full it should not cause a overload, Take a look at the tag on your compressor see what the wattage and amperage is required, maybe it overloads because its a high demand 120v amperage, Maybe you could solve this by running a 220v compressor the start up amp's are not as demandingthe generator does have 2 separate circuits and the hoist is brand new i dont know much about generators .
maybe the problem is that the compressor is cycling and it give a lot of pressure on the generator ?
Did you buy one of those Generac 8000w units? Nothing but problems, from other folks I've heard from. Troybilt has a 10,000W. I don't know the cost.anyony used a generator to power a elctric roofing hoist ? I have a 8k generator that suppose to handle a whole house including fridge tv's etc...
