1 - 7 of 7 Posts
well i looked at these plans and theyre not very specific, they show the pitch of one gambrel roof ,but dont show the pitch of the other one which will probably be different because the span is different, both ridges are at same height, and wall heights are the same also, looking at the roof plan it just looks like a regular gable overbuild running into the other roof but i just cant picture how these valleys are gonna look.
If the lower pitch is the same as the adjacent lower pitch, and the upper pitch is the same as the adjacent upper pitch, then both valleys will be 45° in plan view.
If the span is different and you have ridges meeting each other, then you have a cluster ****.
Custom Builder
Not tricky look at each section of roof pitch on its own ie bottom pitch valley 1 to botom pitch valley 2 do the same for top pitches and buid your valleys. Are the valleys overlayed. Im not sure how your seeing this difficult. Is the bottom radiused that makes it a little tricky if not just a typical irreg valley
1 - 7 of 7 Posts
