Gable vents ''chalking'' brick exterior
1617 Views 6 Replies 4 Participants Last post by  dom-mas
Any ideas on how to remove paint chalking from exterior brick ?
Customer has 3 round gable vents and the white paint has bled ,
but they are in the front of the house and there's no inconspicuous
place to test chems. cleaners etc. Powerwashed at 3500 PSI and
it didn't budge . thanks in advance
1 - 7 of 7 Posts
How about a wire brush?
Varsol? but that may just smudge it
A wire brush unless it is brass or stainless will turn the brick black.
Try a paint remover from a company called Prosoco.
What you probably have is called chalking,aluminum (if that is what they are) is prone to do that.
Brass will turn the brick "brassy"
I have to admit,I take a wire brush to brick about every 10 th blue moon. With that said,possibly the brick I took the brass brush to were colors that the brass was not noticeable because I cannot recall them turning "brassy"
I've only done it once, and it was on old soft brick. The brass is softer than the brick (which is why i chose to use it) and rubbed off on the brick. When i tried to remove the brassy finish I couldn't get it off, not with a pressure washer (set pretty low), not with any cleaners.
Maybe on a modern harder brick the brass wouldn't "grab" the brick in the same way. I don't know, i just won't try again.
1 - 7 of 7 Posts
