1 - 8 of 8 Posts
Justin K
What is the best way to install posts for a free standing deck (elevated)?
1) Posts in the ground surrounded by concrete & treated with extra copper preservative before placed
2) Pour a concrete pier with the top in a sonotube form. Use a metal connector to attach the posts
3) Other???
Obviously both methods would have diagonal bracing from the post to the deck/ beams
Just trying to find out what methods others are using and why
Justin
Sean
Piers with a post base anchor that keeps it elevated - not only is this good in moist areas but others where termites, weed eaters, etc... are a concern
If you want to do the other make sure you have some that are treated for ground contact - as for applying more preservative, that will only take care of the surface & is only really meant for the cuts which should be used whether it is under ground or above
Retired deck builder
I've got a welder who makes up a 6x6 post base made with 1/4 steel primed & painted black for 90 each. The few extra bucks are worth it as they will outperform anything simpson has out. Never had an inspector say one word about them either. Mainly use them on pergolas & pavillions tho.
I do the same for certain applications, but I have to have paperwork showing the weld shop is properly certified.
John Hyatt
Al and I build the same in a lot of areas.
The U shaped steel post brackets my guy makes up using 1/2 '' flat stock are 16'' / 24 '' high. Believe me with the right top and bottom connection the movement is cut to unnoticeable .
Ground contact MCQ is all I can get local. If you look hard enough they stand good for ground contact not placed in the ground. Sneaky little devils. A couple coats of copper green stops rot/bugs altogether.
JonMon www.deckmastersllc.com
1 - 8 of 8 Posts
