Typical detached garage slabs are poured with 2-4" of slope in my area. Some have curbs, most don't.
I've seen a lot of framing methods addressing the slope (I have my preferred approach) and was curious what you all do.
Method I use:
I've found the most accurate and time- (re: cost-) effective method for myself is measuring with a surveyor's level every 12", drawing the slope in CAD, then printing out a numbered cut list for my helper (I am marking plates while my helper cuts).
Some of the other methods I've seen:
- Completely ignore the slope. Frame a square wall and let the garage lean into the alley. - The individual doing this in my area undercuts everybody by ~75%
- Cut a full length shim out of 6x PT material (essentially creating a level curb) - I've only seen one guy do this. I like that you don't have to cut individual studs, and it raises untreated material even further from grade. I don't like needing 6"+ anchors on the more extreme slopes.
Methods I've read:
- Erect: Stand the ends and mark the tall side with a string level. Toe-nail studs, snap a chalk line, and cut each in the air.
- On the ground: Measure the overall slope and cut the tall stud accordingly. Lay interior studs, snap a line, and cut each. (Very similar to my approach, minus a pre-calculated cut list).
So, what's your preferred approach?
Method I use:
Methods I've read:
