There were a few SIP panel homes built here locally but due to the cost of getting material up here I have not seen any done recently. Cost, especially shipping, kill us up here for material.$225 a yard of concrete, $48 for 3/4 T&G subfloor, well you get the picture. With that said the SIP homes I have been in are pretty darn tight and well insulated. The other problem we run into regarding the roofing panels is the snowload, wind and sesmic requirements. But it is diffently another option to look into.
I have also seen a few homes up here built with 2x8 walls - 24"oc. Seen those skim coat with a couple inches of spray foam then remainder of space filled with regular batts. Still does not address the thermal bridge regarding the studs and inside/outside temperature difference. Hence another reason why steel studs just have not been to popular up here. A double wall with staggered studs would eliminate that along with the SIP and REMOTE setup.
