1 - 20 of 35 Posts
I've never had a fitting break off my nailers before and now that I have these 2 max nailers they both broke off inside the threads within a month of having them. To be fair the one I did today I can understand I don't think I could have dropped a joist more perfectly but the other one fell like 4' and broke off. I think that one was a cheaper fitting though.
should think about getting a better gun next time. Duur
Goto a hydraulic supply shop and get some good steel fittings. The brass ones are junk. I never thought I'd admit the amount of money I spend on air fittings. But the expensive 20$ each quick couples are worth the money. Depressing when you have 15 hoses at most times.
Discussion Starter · #12 ·
frankpgosteli said:
it's the **** product you bought. Never in my life have I heard of your issue. It happened to you twice. Wtf buy better plugs
Look genius, as I stated it's not the gun. It's the fitting. I have no problem admitting that the fittings I bought were cheap. But to say it's the guns fault cause the fitting broke is dumb.
1 - 20 of 35 Posts
