I am currently starting to finish my basement. I want to frame around the furnace, and am wondering about desired clearances for walls around the furnace.
I am aware that I need adequate ventilation for the furnace to maximize its efficiency, which I will accomplish via vents.
I also will provide a 48" wide set of mirrored closet doors in case something needs to be removed from the room (i.e furnace a-frame, or water heater).
The wall behind the furnace will be spaced 6" away. The end walls will be 36" away, and the front wall traversing the furnace will be placed 36" away.
Is this adequate? Are there specific codes I need to worry about? Where should I go to check the codes applicable to Omaha, NE?
George
George
