1 - 5 of 5 Posts
I am finishing the rest of my basement and started to put up NON LOAD bearing walls.
I noticed that the walls that the contractor built in the basement have no jack studs in doorways and the header is attached directly to the king studs.
Is this normal? is there a disadvantage to doing this for the rest of the basement?
Why do you even need a jack stud in a non load bearing wall?
I personally don't frame door ways like that. I think it is hacky. But it's ok for non load walls.
I have seen this style before by mexican crews and is excepted by the local building depts.
My advice: frame your door openings in the normal way, meaning kings and jacks and cripples above the header...rule of thumb from my neck of the woiods: give a three inch nailing surface all around the opening..it makes it tighter, and gives plenty of nailing for trim.
-old
smartazz contractor
-old
:w/stupid
1 - 5 of 5 Posts
