My customer's window leaked during an unusually heavy storm last month. First step was to divert the water coming off the roof away from this window and recaulk around the trim. Second step was to remove the wet trim to dry the area and replace. After removing the trim I found the glass is set directly on untreated cedar.
There are four other windows in the house in the same situation. The 1yr warranty is up in Jan. The contractor who built the house has bailed on his partner, the partner is close to going under too. The home owner an ongoing customer, the builder partner (BP) asked if I could look at fixing these things. The BP is paying the bill.
I see two fix options, pull the glass, wrap the cedar and retrim or pull the trim and waterproof the exposed cedar (like red guard) silicone the seam and retrim.
What would you do?
