A four way is a double pole. :whistling:
But I get it, that would be confusing.
a 4 way is an intermediate switch and crosses the lines. A double pole makes an open circuit of the live and neutral at the same time. They look the same but do not function the same.Tinstaafl said:A four way is a double pole. :whistling: But I get it, that would be confusing.
A double pole is a switch that switches 2 poles at the same time. A 4 way is an intermediate and only a single pole switch.Tinstaafl said:Yeah, we know that Barri. But it's still a double pole. :thumbsup:
So let me get this straight. You guys call a switch that only carries a live load but has double throws a DP too! Electrical names over here are so different that UK.Tinstaafl said:Nope. There are two poles.
BCConstruction said:So let me get this straight. You guys call a switch that only carries a live load but has double throws a DP too! Electrical names over here are so different that UK. 3 way here is 2 way 4 way her is intermediate And now 4 way is 2 pole. It's no wonder I come across so many "double poles" put in place of 4 ways over here. So what us a true double pole called?
Maybe that was it, the house was built in 1960, must have been an Englishmen that got the names confused and put in the wrong switch.So let me get this straight. You guys call a switch that only carries a live load but has double throws a DP too! Electrical names over here are so different that UK.
3 way here is 2 way
That's why I'm confused. I have changed out maybe 10+ 4 ways where someone wired them With a true "double pole" over here. If people call 4 ways double poles too I can see why this happens so often here. I'm curious though as to what a true double pole switch is called like in your first diagram.KennMacMoragh said:Maybe that was it, the house was built in 1960, must have been an Englishmen that got the names confused and put in the wrong switch. We don't really call a 4-way a double pole, he was just saying it has two poles. The Leviton web page defines them. Double throw switch is one of these:
That's good, it took me about two hours, I had to do some tracing to see what was going on because I assumed the problem was in the wiring. When the wiring looked good I examined the switch and figured out the problem. If I ever came across this again it would probably take me 20 seconds to figure out.That's why I'm confused. I have changed out maybe 10+ 4 ways where someone wired them With a true "double pole" over here. If people call 4 ways double poles too I can see why this happens so often here. I'm curious though as to what a true double pole switch is called like in your first diagram.
I done one not long ago where it had been wired with a double pole 4 15years and never worked right. Customer said not one electrician who ever tried to fix it could figure it out. Took me 20seconds.
Ok so it's just a case of some people call 4 ways double poles.KennMacMoragh said:That's good, it took me about two hours, I had to do some tracing to see what was going on because I assumed the problem was in the wiring. When the wiring looked good I examined the switch and figured out the problem. If I ever came across this again it would probably take me 20 seconds to figure out. I don't call 4-ways double poles so I won't make that mistake. The one in my first diagram actually is called a double pole.
Because our 3-ways have 3 points, same as yours. A 1-way switch would just be a wire, only 1 point.Ok so it's just a case of some people call 4 ways double poles.
I would also love to know how they concluded that a 2 way is a 3 way.
In the UK its common, switched leg A switched leg B. So it's switched 2 ways not 3 lol
