Status
Not open for further replies.
1 - 4 of 4 Posts
I am purchasing a property. it is a two level home around 2000 sq.ft with slab foundation. The slab has wood column around 8" wide and 8 feet apart around the perimeter of the home and wood column are also used for load bearing Walls inside the home. I would like to know what kind of foundation design it is and if house is considered a permanent structure. House was built in 1986 in VA suburb.
Remodel
Probably a pole barn type of build.
Most places, if it has a foundation, it's a permanent structure.
You say it’s a home. Is it a solid slab? What do the houses around have? Same- different. Is it a pole barn w/concrete around perimeter only
Mike
Capra Aegagrus
Remodeler
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to Register
1 - 4 of 4 Posts
Status
