They do make a wood bleach. It is not going to totally remove the black stains but, it will lighten them. It is something like oxalic acid. I could be way off on the name but, it does start with an O.
I have to disagree ..99% of pros did not decide to take a sanding job in one day and tried.Personally I had hired an employee (a sander) who had learned and worked for quite time with some other pro before.I let him do most of the job and gratually I learned the tricks and skills to do job right.I did not take the first sanding job to test and hope it did not turned out a disaster!I simply was not able to afford to ruin my reputation even in my early days.Here we suggest-not force-our opinions for the best solution.It is up to him to judge his ability if enough to take this task.I agree it is not a rocket science, but it is not like painting job either, if you paint and did not turn good,you simply paint over. I have to add that wood floor installation is fairly easy, as long as follow the instructions-it may take longer than expected-but sincerely I do not suggest sanding job to anyone who has no experience with.I'd like to agree with the "hire a pro" guys...but...that's only a generalization for most situations. If you have the ability, time and desire to tackle such a task, I say go for it...it isn't rocket science. All "pros" did a first one too and unless it was a total wreck when they were done I have to assume they will agree. There are people that have the ability to refinish a floor or any other task of moderate difficulty... and those that don't.
So there you go. Don't pay retail. Hire a day laborer with sanding experience to show you the ropes.I have to disagree ..99% of pros did not decide to take a sanding job in one day and tried.Personally I had hired an employee (a sander) who had learned and worked for quite time with some other pro before.I let him do most of the job and gratually I learned the tricks and skills to do job right.I did not take the first sanding job to test and hope it did not turned out a disaster!I simply was not able to afford to ruin my reputation even in my early days.Here we suggest-not force-our opinions for the best solution.It is up to him to judge his ability if enough to take this task.I agree it is not a rocket science, but it is not like painting job either, if you paint and did not turn good,you simply paint over. I have to add that wood floor installation is fairly easy, as long as follow the instructions-it may take longer than expected-but sincerely I do not suggest sanding job to anyone who has no experience with.
