1 - 9 of 9 Posts
Hi all! I have an ancient Pioneer unit (80-P) and I believe the fan limit switch has failed (the fan only comes on when I tap it). It has had a good run, being dated 11-59, so I think it's worth trying to repair than replace the entire furnace.
I've been trying to find an aftermarket replacement for the part (AF-310), and the closest I can find is a Cam-Stat part #L36-140.
Is this an appropriate replacement part or might there be something better? Thanks for reading!
Professional Contractor
fan limit
Any will work as long as the probe is the same length, it has a on and off cam or setting, and of course the most important is the limit setting.
Contacts should be rated for the max amp draw of your blower fan.
Access Heating & Air
ALLTIME805 said:
I'm in SoCal where there is no winter. I do value efficiency of course but my bill is usually below $50. New furnaces look like toys compared to this thing.. ugly, multi colored steel, and a helluva track record. I'm not positive the new ones will give me 55 years + lol...
Good point there!
www.accessheating.com
1 - 9 of 9 Posts
