Thanks would like to see the picturesI've had plenty of drywall carriers over the years, worked great for 4x12's
Basically metal tubing welded t-handle,shaft and flat hook on bottom. about 24'' long.
Will try to post pic later.
It actually grips Melamine. That is my biggest problem, I just can not put a hold on it anymore.I also have the gorilla grip and like it a lot. It puts all the weight on your bicep and shoulder. You just hold your hand next to your shoulder, bend your knees and lift straight up. No more bending over to get underneath the sheet. Its crazy how much easier it is to carry. I can move 3/4 sheets of mdf and melamine up and down stairs easily.
I saw that, that is funny.
:clap::clap:
It works fine for melamine. The inside of the jaws are coated with something very similar to truck bed liner. There's no chance of it slipping out. The way the jaws work the heavier the piece is the more they clamp down, so I think it would hold even if they were smooth.tonylumps said:It actually grips Melamine. That is my biggest problem, I just can not put a hold on it anymore.
If she showed up on any jobsite I bet no one would have trouble picking up anything.
You're only 31 :laughing:I use a 19 year old kid who works for $10/hr.
He's great.
Dude! Look at the title of this thread! Even the ultralight Sheetrock is over 50lbs per sheet, so 3 would be over 150 pounds. Don't think I'll be "slinging" that anymore! As for multiple sheets, two are about all I can do. The third, middle sheet tends to slide out. 1/4" ply seems okay, though. Anything heavier overcomes the friction and slips.steex said:I like the idea of that Gorilla Gripper, but I don't think it will work for more than one sheet. Even a single sheet of 3/4" ply is manageable, and most things we carry are lighter than that, so unless it somehow allows you to sling around three sheets of 5/8" drywall it doesn't seem worth the $50.
