1 - 1 of 1 Posts
I'm a Mac
Discussion Starter #1 (Edited by Moderator)
It all starts with a solid foundation. That has been an expression forever, I am sure we have all heard it and even used in paraphrasing someone.
ICF's or Insulated Concrete Forms are always gaining popularity in the construction world, although still a small blip on the radar map every year the manufacturers boast about sales increasing, year after year. As codes are changing and insulation requirements are getting stricter ICF's are growing in popularity, as a matter of fact, and I am going off subject here, January 1st, 2012 the building code in Ontario Canada changes and ICF's are expected to be seen in 7 out of 10 foundations going in, that's 70%, considering today it may be 3%, that's an unheard of increase, now lets see if it happens.
On to the footings...for ICF's
The footing is the first and foremost important part of ICF construction. Over the years I have seen footings in tract homes out by 6" and the wall forming crew shows up, sets up there forms and pour away using the lowest point as the top of wall, so the suppose to be 8'-0" basement becomes ~7'-6" and no one really cares, it's a tract home, the people who buy them, they don't really notice or don't really care.
With ICF, the industry touts the importance of a level footing, ~1/4" and with good reason. Since ICF blocks are designed to lock together like Lego Blocks they want to sit on a flat level surface and if the footing is too high, too low, out of level it needs to be fixed. There are a few ways to correct it, one being to shim the wall as needed to raise the blocks to the highest point, or cut the blocks to meet the lowest point. What for, when all it is going to take is a little bit of extra time to check and double check with the laser prior to pour and again check it as you are pouring the footings.
I will be the first to admit, I am the most expensive footing quote you will get, because I am building the ICF wall on top of it and I know how much time I spend building the footing right. I have seen people balk at my footing price because his slab guy or carpenter (who's usually are not bad) give a bid for up to 1/2 of what I charge. There is a way to overcome this, if I don't build and pour the footing and I show up to start the wall and find the footing out by more than ~1/4" or the steps footings were built to the wrong dimensions I charge $ XX.XX per foot...for the entire length of the footing. Now if you take this amount into consideration, it usually exceeds the savings by using someone else.
Some people tell me to settle down, that I can't do that, that it is ridiculous, etc. But at the end of the day I priced the ICF work which did not include me losing a day or sometimes two having to get the job started because someone just didn't care enough and was rushing. I went to a job last summer, the GC had his crew do the footings just to keep them busy, as usual I was too expensive. The older gentlemen on site, about 62 or so, couldn't understand why I was complaining...All as he said was 'It's just a footing, no one is ever going to see it'. Well after seeing us mess around for 2 days fixing his 'it's just a footing', he understands why I preach the importance of it...and charge for it.
This blogging is new to me, if you want more info on ICF's leave comments below and I will reply
1 - 1 of 1 Posts
