Footing for a garden wall
7667 Views 8 Replies 7 Participants Last post by  custom patios
Edited
1 - 9 of 9 Posts
Given that it is in the garden, I would want to go mortarless if possible and just stack the brick. It might be more stable to use retaining block.
You could do one course of brick alongside each other lengthwise, then the next course with the brick going perpendicular. I have a wall like this which has been standing for 7 years and the brick were fairly irregular old terra cotta type brick. The wall must be 4' tall.
I would just put in a trench maybe 18" deep and as wide as a compactor and compact some 3/4" minus stone in there and stack on that.
How is the drainage in the area you want this?
Plumb=lead, plumbers used to use lead pipe for nearly everything, Thus Plumbers.....
Plumbers and refrigerators have saved more lives than all the doctors and nurses ever....
You may find this tech. note by the B.I.A. helpful. Figure four would be applicable to your project.
http://gobrick.com/Portals/25/docs/Technical Notes/TN29A.pdf
Reactions: 2
Edited
Holy mackerel... that's a fantastic link!
Thanks so much. I'll study it fully and post when I'm done (hopefully August)
Keith
You are quite welcome. Good luck on your project.
Over code, I would put ladder wire corners in every course extending at least 2 or 3 feet, if not all the way around. Every brick planter issue I have seen is at the corners.
May I suggest possibly 16 x 4,...install 12" wide trench footing possibly belled to 16" if poor soil exist. Place your crete just below grade and start building.
As far as the wall, you can back it up with 4" cmu, I'd probably use 6" so I could extended rebar from the footings and grout it solid when your done.
Then you could cap it with some thermal blue...The wifey will love ya and the wall will hold up nicely over the years.
Kinda like this little retainer I built with another side to it...
Reactions: 2
1 - 9 of 9 Posts
