1 - 20 of 39 Posts
Do you need to clean the gun when switching types of foam or can you just screw on the new can, dump a little and then go?
We now have a sub-floor gun, a gun we will use for doors and window, and then one we will use for everything else. We don't use enough of any other type to keep multiple guns going for every one.
What's you definition of servicable ? You can take the fun apart ?
I had one of out Hiltis do a slight clog. It was getting dark and no electric on-site.......
I took awhile but I got it to unclog itself - the retainer ball just got stuck a bit.
Parts are available and able to be replaced.
I'm a Mac
Store them with can left on, turn the flow to off.
Why you have different ones for sub floors and then windows/doors? Just use the same foam for all applications.
Hilti has a deal, buy 3 cases and the gun is free. It's not an advertised deal, just ask for it and they give it to you.
Chris Johnson said:
Store them with can left on, turn the flow to off. Why you have different ones for sub floors and then windows/doors? Just use the same foam for all applications. Hilti has a deal, buy 3 cases and the gun is free. It's not an advertised deal, just ask for it and they give it to you.
When you guys are talking about subfloor, is this gluing subfloor down with foam instead of construction adhesive? If so, what's the benefit?
Cost, quality, something else?
Discussion Starter · #18 ·
Love me some Concrete
I have a few of the Great stuff #14's and they work good. I do shoot cleaner through them when I change the can but seldom have to totally clean it out. I did it once on a day a storm rolled in and I was huddled in the trailer, figured it was a good time to spruce things up!
I have had 2- #13's and really did not like them, I'm not sure if it's all the plastic or what, but had not very good luck. They say that anything over 30 days and you should clean them out, I know I've went at least 60 days with no problems. I tend to keep 1 loaded for doors and windows.
1 - 20 of 39 Posts
