Foam bottomed tub is noisy when stepping in.
14K views 19 replies 10 participants last post by  Golden view
I have a tub in a remodel I did that's surprisingly noisy/creaky when stepped in. It's one of those with a foam/felt support underneath an the instructions specifically say it doesn't need a mortar base or anything under it. I probably should have though.
Any thoughts how to quiet this thing down? I can remove drywall from the back if needed. Maybe drill through the foam and somehow inject mortar? Try to carve out much of the foam and spray new foam under there?
Tub is porcelain on steel.
#7 ·
God, I hated those wretched tubs.
IRC, one time drilled holes thru subfloor every few inches and blew a full can of silicone or Lemon Pledge all along the way.
Back then, Lemon Pledge was my go to for just about everything that moved or squeaked, so I'm guessing that.
In any case, next time have turd herder put a piece of tarpaper or tyvek down.
And then stop using those sh!tty tubs.
#10 ·
It could be the ledger if you used one.
I had one with a terrible squeak,. When the customer showed me I was a little pissed off as if what now......
Gave the side of the tub of rap with my leg and squeak when away. :laughing:. I think the mud job and tile floor pinched the apron a bit I was causing it to react. That was the end of it
#14 ·
Those tubs sVck. For lightweight tubs, try the AS ones with the composite underside next time...much more solid.
It could be that foam base kept the apron from contacting the subfloor evenly...or the ledger is moving. You might need to pull a couple floor tiles to get some shims under the apron, as well as spray foam the heck out of it underneath.
#15 ·
This IS an American Standard tub. Maybe exactly what you're talking about. Porcelain on steel.
Funny thing is another remodel I'm in the middle of got the same problem. Just yesterday I removed and reset the tub in a mortar base to fix the problem. I'll be doing that from now on.
Still not sure how to best deal with the other one that's in a completed project.
#20 ·
Revisiting this to report back.
Drilled about 10 1/2" holes through the foam at the bottom, then attached 1/4" pex as an extension to my foam gun and filled all those holes, presuming it would expand under the tub and fill most of the space.
Completely solved the problem, from an access "slot" no taller than the base trim on the adjacent wall.
