U
Unregistered
·Guest
I want to control a flourescent light from a 2 way dimmer switch for a halogen circuit. Can this be done using some sort of relay/switch where the dimmer can turn the flourescent light on when halogen circuit is on and turn off both circuits when dimmer is off? Are there relays around that can be used to switch the flourescent light using 2 circuits (1 is the dimmer circuit, the other is the power from the mains lighting to provide contant power to the flourescent)?
Thanks
Thanks
