1 - 13 of 13 Posts
I have the same problem.supply house says I need a low power factor ballast, but unable to get one from manfucture.
That supply house guy is clueless.
Electronic ballast operates at a fundamental frequency of 20-40KHz and harmonics up to a few MHz can be generated which can interfere with the intermediary frequencies that fall within that range. If properly grounding the luminaire and re-locating the radio won't solve the problem, another approach is to move onto a magnetic or a hybrid ballast. A hybrid ballast is a magnetic ballast that cuts-off the cathode heaters to save energy once the lamps are started. They're used in health care facilities where HF drive interferes with medical equipment.
I own stock in FotoMat!
In case no one was ever bothered, take a look at the bulk of your electronics. Read the words about interference on the back/bottom.
"This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
1. This device may not cause harmful interference, and
2. This device must accept any interference received, including any interference that may cause undesired operation."
In short, you're hosed.
Many electronics ballast are not FCC rated for residential use. To be proper, for residential installation, the ballasts should be FCC B rated for residential application. HPF and FCC B ratings are mutually exclusive.
What about the radio, though?
1 - 13 of 13 Posts
