Flooring Identification Help
1835 Views 7 Replies 6 Participants Last post by  Sir Mixalot
Hi, I have a remodel project. Client has existing engineered wood floors. Looking for flooring product to replace portions after renovation, but so far unsuccessful. No brand name on wood or a box that the homeowner saved can anyone help identify from these photos of the box.?
1 - 8 of 8 Posts
Can't you scan the bar code?
A picture of the material might help, too.
First thing I thought of, and I hit all the UPC lookups I could find with no valid result. Problem is, there's no "worldwide" central registry of those codes.
Even if you get the same stuff they won't match the old because of wear on milling blades and die lots..
posting in Flooring section might yield better results as well.
Moved. :thumbsup:
1 - 8 of 8 Posts
