1 - 16 of 16 Posts
Flooring Guru
I currently use a scale ruler and a pencil to make scale drawings of floor plans. Does anyone know of a computer program that is useful? I would like to try one for free if I can. Alot of the programs I have come across, are of the autocad variety and are too technical for my application. Any shareware or freeware ideas out there? If not, which one should I buy. I dont need any of the 3d stuff, I just want to scale draw on the ole puter, then print it out to 1/4 scale.
3D Home Architect it's basiclly the same as chief Architect but you can buy it at walmart for about $12 you can export your floor plans to Autocad .dwg and work it up more from there it saves alot of time setting up autocad too because your working table will to size of your plan the only thing left to do is set your dimentions and change from decimal to fractional
If you only want 2d I would suggest autocad light. Is very compareable to autocad itself, I dont think it is too technical, I use both auto cad LT and auto cad. and its price is quite a bit less than autocad.
Flooring Software
If you're still looking for flooring software, there are several products on the marker, from the slighty weeny underpowered all the way up to mega muscle monster... some software packages are good for retail type flooring jobs, others have enough horse power to handle big commercial jobs.... at just about every price point from free to mega-bucks...
You get what you pay for....
After several months trial error and research I have found and favor one product which I thinks suits my needs as a commercial flooring contractor...
I also double as a computer guru and hi-tech wiz. I'm pretty up on all to new gadgets that all the "bleeding edge" flooring guys are using... so send me a pvt email at: [email protected]
All the best,
Tony Parker
I use a spreadsheet program for all my floor plans. I have a template set up as graph paper. I can do all of my floorplans like this just as fast as I could with a ruler and paper. Usually one sq=1ft. but it can be changed right down to the inch and smaller if needed.
If never found flooring software to be much worth the expense unless you're doing a whole lot of major commercial plans. If your work is mostly residential this is all you really need.
Flor, if you want to message me I can explain this a little better. Maybe you need something more powerful but from what I understand about your forte this should do it.
Don
1 - 16 of 16 Posts
