This is not a shower. Just a 6' x 6' bathroom - floor porcelain 6x6 border - with 12x12 offset in the field. Wainscot of 6x6 ceramic. No cove base.
Walls or floor first ? Why so ?
Me too that is the way I do it.I'm an idiot,
This way seems most efficient most of the time.Or leave out the bottom row - then floor tile - bottom wall course on top of floor tile - up 1/8 for unsanded grout.
Yes it defiantly soaks up time and with bigger tile you have to measure both ends of the tile down to the floor and cut the tile on a slight taper if needed. But like you said it looks better with the floor tile tucked under the wallFloor tile butted to wall tile always looks bad with the grout joint(hairline crack) due to movement. It let's you tuck that edge under the wall tile. Pain and I hate doing them when it's a bunch of bathrooms, just soaks up time.
