Status
Not open for further replies.
1 - 4 of 4 Posts
I have an existing central basement floor drain but I want to install an additional drain (6’ away) and closer to my high efficiency furnace so I can directly drain condensate /water. Planning to connect into the existing drain with a wye or tee directly above the p trap. Does the wye have to be located just above the trap water level (A) or above highest level of the horizontal exit pipe (B) ? See attached drawing?
I don’t have a lot of space below the finished floor grade to move the tee/wye up in the assembly, so I may have to abandon the plan if the below is not appropriate.
Font Handwriting Rectangle Parallel Drawing
4 Potential Problems with Floor Drains
1 ....Debris Backup. There are several different types of debris that can block up the drain and the pipes that drain leads to. ...
2 ....Pipe Crystallization. When certain liquid like soap and sugary liquids flow through pipes, they can dry and leave sediment behind. ...
3.... Overflow Issues. ...
4...Raw Sewage Odor.
1 - 4 of 4 Posts
Status
